Netbrain
Go BackThe Net-BrainerNetBrain Product Token expiry
Reply
Old 08-22-2018, 04:11 PM
mswamy mswamy is offline
Default Token expiry
Hi,
I would like to know for the Netbrain API, how often does the Authentication token expire? Can we set up the expiry timeout?
Thanks
Old 08-22-2018, 11:28 PM
Administrator
Default Re: Token expiry
Quote:
Originally Posted by mswamy View Post
Hi,
Thanks
Hi,
The token timeout is same with the session timeout of the user you used to get token, by default, the session timeout of each user is 4 hours. In the User Preference dialog, you can select more options based on your needs, from 15 minutes to 8 hours, click Save.
Please refer to this link for User Preference:
https://www.netbraintech.com/ftp/IE7...preference.htm
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
