Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time Network Device SMNP string is getting failed at NetBrain 7.01
Reply
Old 09-24-2018, 08:26 AM
Sathish.062 Sathish.062 is offline
Default Network Device SMNP string is getting failed at NetBrain 7.01
Hi,
The SNMP string that we have on the routers don't seem to work. NetBrains goes out and contacts routers first based on SNMP string, they all fail when using SNMP. The older version of NetBrain is able to connect via SSH. The new version seems to need SNMP and SSH in order to work. Can you guys help in figuring out why the SNMP string doesn't work.
Advance Thanks
Old 09-24-2018, 09:13 AM
Default Re: Network Device SMNP string is getting failed at NetBrain 7.01
Hi All,
Getting below logs in netbrain while discovering. Kindly suggest asap. SNMP string is same on network devices and Netbrain 7.01
Ping [108.58.212.26] via Proxy Server(10.220.70.94); Succeeded
Send RO = [ODFMC-RO][version:v2c] to [108.58.212.26] via Proxy Server(10.220.70.94); Failed:SNMP++ Get Error, SNMP++: SNMP request timed out (-5)
Send RO = [ODFMC-RO][version:v1] to [108.58.212.26] via Proxy Server(10.220.70.94); Failed:SNMP++ Get Error, SNMP++: SNMP request timed out (-5)
Send RO = [NETMAP RW][version:v2c] to [108.58.212.26] via Proxy Server(10.220.70.94); Failed:SNMP++ Get Error, SNMP++: SNMP request timed out (-5)
Send RO = [NETMAP RW][version:v1] to [108.58.212.26] via Proxy Server(10.220.70.94); Failed:SNMP++ Get Error, SNMP++: SNMP request timed out (-5)
Send RO = [ODFMC-RW RW ACL_ODFMC_RW_MGMT][version:v2c] to [108.58.212.26] via Proxy Server(10.220.70.94); Failed:SNMP++ Get Error, SNMP++: SNMP request timed out (-5)
Send RO = [ODFMC-RW RW ACL_ODFMC_RW_MGMT][version:v1] to [108.58.212.26] via Proxy Server(10.220.70.94); Failed:SNMP++ Get Error, SNMP++: SNMP request timed out (-5)
Send RO = [DXNtzh1223_#][version:v2c] to [108.58.212.26] via Proxy Server(10.220.70.94); Failed:SNMP++ Get Error, SNMP++: SNMP request timed out (-5)
Send RO = [DXNtzh1223_#][version:v1] to [108.58.212.26] via Proxy Server(10.220.70.94); Failed:SNMP++ Get Error, SNMP++: SNMP request timed out (-5)
Send RO = [HCNNY-RO][version:v2c] to [108.58.212.26] via Proxy Server(10.220.70.94); Failed:SNMP++ Get Error, SNMP++: SNMP request timed out (-5)
Send RO = [HCNNY-RO][version:v1] to [108.58.212.26] via Proxy Server(10.220.70.94); Failed:SNMP++ Get Error, SNMP++: SNMP request timed out (-5)
Send RO = [B1ack5ky][version:v2c] to [108.58.212.26] via Proxy Server(10.220.70.94); Failed:SNMP++ Get Error, SNMP++: SNMP request timed out (-5)
Send RO = [B1ack5ky][version:v1] to [108.58.212.26] via Proxy Server(10.220.70.94); Failed:SNMP++ Get Error, SNMP++: SNMP request timed out (-5)
Discovery of 108.58.212.26 complete
Old 09-28-2018, 08:04 AM
Jia.Xing Jia.Xing is offline
Quote:
Originally Posted by Sathish.062 View Post
Hi,
Advance Thanks
Hi Sathish,
SNMP Get Errors may have two possible causes:
1. SNMPv1/v2c community string is wrong, or SNMPv3 authentication is wrong. In your case, I suppose this is not the root cause.
2. NetBrain Proxy Server does not have SNMP access to the network device, even if the community string is correct. This may be due to firewall settings or security settings. And it may be the root cause in your case.
Please check NetBrain Proxy Server's (10.220.70.94) SNMP access to the device(108.58.212.26). You can use any SNMP walk tool to test it on Proxy Server machine.
Reply
Bookmarks
Tags
BGP, CCIE, CCNA, CCNP, Consultant Edition, Network Design, Network Discovery, One-Skill, one-skill-at-a-time, Qmap Reader
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
