Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time Is there a way to arrange large number of icons?
Reply
Old 11-26-2018, 01:31 AM
netbmed netbmed is offline
Default Is there a way to arrange large number of icons?
In a map with a large number of devices - is there a way to tell netbrain to arrange the icons in a particular way? You can see in the attachment that I have almost a decent semi-circle of leaf switches below four spines. But still looks kind of herky jerky. Any recommendation?
Old 12-02-2018, 10:34 PM
Administrator
Default Re: Is there a way to arrange large number of icons?
Hi,
Yes, in IE7.1a, NetBrain provides auto layout manager function which automatically organize map objects based on network infrastructure, sample layout, or geometry. With this function, you can save manual laboring for map layout and it will be more convenient to find or manage devices on a map.
Please kindly refer to
https://www.netbraintech.com/docs/ie...yout-style.htm for more details:
The function supports the following types of the map layout.
▪Layout by Tag organizes devices based on their tags to reflect real network infrastructure, such as the three-layer network hierarchy. To use the layout by tag:
1.Create a Layout Style
2.Apply a Layout Template on Map
▪Layout by Sample organizes devices based on a sample map. To use the layout by sample:
1.Save a Map Layout as Sample
▪Layout by Geometry organizes devices based on geometric shapes.
Old 04-03-2019, 04:30 PM
gabrielshorn gabrielshorn is offline
A way to do layers, like you can do in Visio, would be great in NetBrain. That way, you'd be able to select/de-select layers to simplify the map for a variety of purposes. I realize you can do some of that with site manager, but there are limitations.
Reply
Bookmarks
Tags
Network Design, One-Skill
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
