Netbrain
Go BackThe Net-BrainerNetBrain Product vPC supported?
Reply
Old 09-05-2019, 04:17 AM
nrlourenco nrlourenco is offline
Default vPC supported?
Hi All!
I understood vPC is supported on v7. However, when building a L2 map, I can only see the vPC peer link.
For the other vPC's, as an example, the interfaces that connect to a FW are represented with a "vPC" link between the 2 switches and the interface description shows only the vPC number (not the physical ifaces). In real world, they are connected to a FW cluster.
Any idea how to represent vPC on a L2 map? Or it is not supported?
Cheers.
Old 10-10-2019, 04:12 AM
Administrator
Default Re: vPC supported?
Case#00107458
Reply
Bookmarks
Tags
CCIE, CCNP, Firewall, Network Design, Network Discovery
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
