Netbrain
Go BackThe Net-BrainerNetBrain Product Display trunk intf instead of mgmt intf
Reply
Old 10-21-2019, 06:02 PM
trevaskis trevaskis is offline
Default Display trunk intf instead of mgmt intf
I'm trying to figure out how to hide the map links for the mgmt interfaces and display additional L2 topology information. Do I need to make a new data view template or is there an option/feature that I need to modify. Thanks
Old 10-22-2019, 01:37 AM
Administrator
Default Re: Display trunk intf instead of mgmt intf
You can just delete the management links on the map by selecting the link and press the "Delete" button on the keyboard. To display L2 topology, you can click the "+" on the device icon, select L2 topology from the drop-down list, and check the corresponding L2 neighbor you prefer.
Please do not forget to save the map for the change.
Old 10-23-2019, 01:07 PM
Thanks, that worked great.
Reply
Bookmarks
Tags
Network Design, Network Discovery
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
