Netbrain
Go BackThe Net-BrainerNetBrain Product Easiest way to bulk update credentials in Netbrain
Reply
Old 01-29-2020, 04:06 PM
jsanders jsanders is offline
Default Easiest way to bulk update credentials in Netbrain
We are updating all of our devices from SNMP V2 to SNMP V3. I don't want to get rid of the V2 config in our devices until I can verify that V3 is working as expected. How can I select a number of devices and tell them to use the V3 credentials instead of the V2?
Old 03-02-2020, 09:05 AM
JustGlenn JustGlenn is offline
Default Re: Easiest way to bulk update credentials in Netbrain
In your case i would just export the settings (On the bottom when you are in the network settings) and delete the v2.
Once you see the V3 is not working, import the file you exported before and delete the V3 version.
I think that is the best way.
Old 03-10-2020, 06:39 AM
Administrator
Thanks JustGlenn's help. It is a good method to achieve the goal.
jsanders,
there is another method, you can create a group for the test devices. Just add the new V3 credential to Network Settings, then edit the Shared Device Settings of one test device on the map, then apply the new settings to this group, please see attached snapshots.
Reply
Bookmarks
Tags
Network Discovery
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
Copyright © 2000-2010 Jelsoft Enterprises Limited.
Copyright © 2009 NetBrain, Inc. All rights reserved.
