Netbrain
Go BackThe Net-BrainerOne-Skill-at-a-Time Network Resiliency testing
Reply
Old 01-26-2019, 03:48 PM
bkarim bkarim is offline
Default Network Resiliency testing
Hi,
I am new to netbrian and still discovering its features. I have been asked to find out if we can somehow test the resiliency without shutting down the interface or the device physically to know if the DR is working. This will be required for testing Nexus, 6500, with BGP and ospf.
Example would be if we have 2 paths from device A to Device D. i.e
ABD & ACD where primary path is ABD. can we test if B stops working would the traffic follow the path ACD or not without making a change to network.
I have seen some documentation where we can setup and can see the traffic path with live packet transfer/capture. If possible can we apply the same for the resiliency testing ?
Kind Regards.
Old 01-30-2019, 11:35 PM
Administrator
Default Re: Network Resiliency testing
Hi,
I am sorry I am not sure which document you are referring to, and which version you are running.
I have the following option based on your description, and the guide links are based on version v7.1a
1. Calculate the path with option “L3 Active Path” set, which makes the L3 path calculated by using live data from the devices.
Pleaser refer to these links for guidance:
https://www.netbraintech.com/docs/ie...ing-a-path.htm
https://www.netbraintech.com/docs/ie...h-settings.htm
2. Traceroute the actual packet transfer, and then Map traceroute result on the map.
How to perform traceroute in Netbrain and map the result: https://www.netbraintech.com/docs/ie...traceroute.htm
3. Use Qapps to monitor, the following Qapp may help to test resiliency:
Overall Health Monitor
Monitor OSPF Neighbors
Monitor OSPF Running Status
Monitor QoS along Path
How to run Qapp: right click on a map and select Run Qapp.
Reply
Bookmarks
Tags
BGP, Network Design, Network Discovery, Network Troubleshooting, One-Skill, OSPF
Search this Thread:
Advanced Search
Display Modes
Forum Jump
Powered by vBulletin
Copyright © 2000-2010 Jelsoft Enterprises Limited.
Copyright © 2009 NetBrain, Inc. All rights reserved.
